jason_class
Member level 5
schottky
Dear All
I would like to know what actually breakdown voltage is for a Schottky diode? Is it the reverse bias voltage of a diode that cause extremely excessive leakage current same as an ordinary diode?
Let's say metal layer connected to Silicon and it is a schotty diode, if there is a small circular metal void underneath the metal line but at the silicon surface, will the breakdown voltage be higher or lower than usual and theory that supports this.
Thank you for your help in advance.
best rgds and thanks
Jason
Dear All
Jason
