what is the betst Cypress solution for a low speed USB ?
beuch
Member level 3
Member level 3
France
USB solution
Hi all,
I would like to know what is the better Cypress solution for a low speed USB device.
There are so many devices on Cypress web...
beuch
Eventually look at FT8U245AM chip from FTDI (www.ftdi.co.uk). I understood that Cypress it's a little bit too expensive.
Cheers
USB low speed
You can use CY63001A is a good choice and is not expensive. This device is very used in software keys. I have attached a pdf for your information. Regards.
After a small investigation it seems Cypress solution for low speed need is cheaper than FTDI.
Thank you for help.
beuch.
just keep in your mind that USB need (@ host side) a driver and it's a real pleasure time to developp a "Windows driver model" one... (ironic :D)
so the real complete solution I use is FTDI, cause don't matter of how windows manage usb part....
with USB : just
#include "ftd2xx.h"
and use window.h function to link your code to ftdi dll :
ptr_on_dll = LoadLibrary("Ftd2xx.dll");
then :
ptr_usb_Open = (PtrToOpen)GetProcAddress(ptr_on_dll, "FT_Open");
That's really easy... :)
You are wrong Maziar, FTDI products are low end full speed, but it's true they are expensive.
beuch
FTDI test circuit
hello friends,
I´ve already bought a FT232AM chip and made a serial-usb converter test board to test this IC. The hardware seems to be ok but I simply cant install it in win98. I´ve contacted FTDI and sent tehm my sch, they told me the hardware was ok but they told me also that win98 had problems with drivers and said I had to update the OS and install some drivers. I´ve done all they said but still not working... Any suggestions??? The IC seems to be very good, expensive but good...
regards,
2000
I use W2K and works fine... If you want to ship up that WIN98 OS... W2K would be a good choice. :)
I've been using the FTDI product. Check it out. Makes
the whole job easy.
