Bus Master
Full Member level 3
- Joined
- Dec 9, 2001
- Messages
- 186
- Helped
- 9
- Reputation
- 18
- Reaction score
- 3
- Trophy points
- 1,298
- Location
- Just behind You ;-)
- Activity points
- 1,455
5v_rs232.htm
Hi there,
any body knows the best way to get a 5V Supply from PC's serial port. I need only about 3 to 4 mA at 5V to supply some interface ICs.
I've turned the line DTR ON (Pin no. 4 at the 9 pins version), this gave me a 12V on this pin, and this was quite enough to turn on a 78L05 voltage regulator, which supplied the requested 5V.( Note that you have to connect the DTR line to the I/P pin of the 78L05 IC through a forward diode. This is important because the DTR pin supplies a -12V when low, which may destroy the 78L05).
The strange thing is: I've tried the circuit on a laptop, and i had no supply voltage. this was because the DTR pin gives about 7.3V when high, which was not adequate to turn ON the regulator. May be this was an accepted voltage level for the RS232 signals. ( Hi = signal >3V, Low = <-3V). Also, in Handheld devices, when it comes to power consumtion, this is so vital argument and needs to be minimized.
My question is: How to achieve a stable design for this situation, i need my circuit to work on Desktops ,Laptops and any IBM Compatible with a standard RS232 port.
Thanks in advance,
Hi there,
Thanks in advance,
