What is the best SW package used in the Design of Microwave SIPs ?
khouly
Advanced Member level 5
EGYPT
I want to know about SIP design
what is the best SW package used in the Design of Microwave SIPs ?
are there ant trainging files for ADS or AWR on this topic ?
Khouly
SIP Design
This book may help you
SIP Design
this book is related to fabless IC design businesses
but SIP is the System In Package
khouly
Re: SIP Design
SiP, If it is a fully RF SiP and uses same process technology we can use ADS I guess. Usually System in package contains digital portions also which are fabricated using differnt process technology (may be 65 nm CMOS) different from RF. I have read some where the processing speed required by each is different and it is difficult to simulate the system as a whole. We can do part by part simulation inside the SiP when compared to full simulation of SOC (system on chip which uses single wafer and Technology).
I am not an expert in this and my views may be wrong. Please go thru below links for more.
http://www.sophicam.com/documents/SipvsSoc_EETIMES_mar_05.pdf
regards
GV
    khouly
SIP Design
i am talking about fully RF SIP , like PA modules front end modules for microwave receivers
khouly
    khouly
Re: SIP Design
Hi Khouly
I am attaching one IEEE paper which will give you good idea about SIP & its applications.
Also See the toshiba's pdf it is also has good explantions
Regards,
Abhishek
:D:D:D
Re: SIP Design
Toshiba's PDF
    khouly
    khouly
