what is the best input value used in OTA for testing?
wael_wael
Full Member level 4
Full Member level 4
hi every body,
when i design OTA, what is the best value as input i have to use for test it? is it 1v, or less than that?
regds
well it depends on your gain and supply voltage. Basically, it is not important AS LONG AS IT DOES NOT SATURATE YOUR TRANSISTORS.
    wael_wael
thank u for the answer, the VDD=1.8v. can i use 1v as input.
regards
Certainly Not, if you are designing an amplifier.
Depends on your circuit: if you are designing a buffer.
    wael_wael
it depend your circuit, p type or n type input.
    wael_wael
wael_wael said:
hi every body,
regds
It is up to you SPEC of system.
And the input value should be less than the linearity of it.
    wael_wael
