Brittoo said:hi ee484
Also, in a nfet, when the Source and backgate are shorted and you are connecting them to a different net rather than Gnd, you would need to isolate this backgate from the substrate. In this case, a DNW is required. Else, we come across soft connection again.
Regards
Brittoo
leohart said:ps:Most analog students were told to always connect the backgate of nmos to gnd in nwell process,and vice versa when you use a pwell process. I don't see why to connect the b and s then to a different potential?I know this could reduce the body effect,but normally this was used in disceret mos design?
