rollaite
What exactly is signal to ground ratio? is it just ratio between the number of signal pins to the number of ground pins of a connector? If so, do we need to consider the power pins as signal pins? How important is this ratio to consider? I mean in what applications/scenarios this ratio becomes critical?
Thank you very much in advance!
- Rollaite
- Rollaite
