What is rms bandwidth?
root mean square bandwidth
RMS is an indication of the energy in ab AC signal.
The RMS bandwith is normally the -3dB bandwidth of the measuring instrument
what is rms
yes
the RMS bandwidth is the effective bandwidth of a filter. and it is defined as the bandwidth of an idial filter if it pass the same amount of energy that the real filter pass.
rms bandwith
to klystron:
what is the relationship between rms bandwidth and -3dB bankwidth?
Thanks
root mean square bandwith
RMS is just the average voltage of an AC signal which is 1/√2 × peak~peak voltage of the signal, the word bandwidth can often be found to describe the frequency response of an amplifier, it is usually measured from the 3dB roll off point of the highest frequency to the lowest frequency of an amplifier or vice versa. eg. if an amplifier has a 3db roll off point at 10Hz and 100hz, it has a frequency response of 10hz~100hz and bandwidth of 90hz.
The 3dB roll off point is the same for RMS or Peak~Peak voltage, the bandwidth is determined by the amplifier that amplifies the signal.
rms bandwidth definition
the rms of any ac signal vsinωt is
( √∫v²sin²ωt dωt )/2pi
the bandwidth is that of the ac signal not the rms
For a filter with a continuous spectral response, RMS bandwidth is probably adequately described as the same as 3 db bandwidth. More formally, RMS bandwidth is equal to the normalized second moment of the spectrum.
See Equation 3 in: **broken link removed** and remember to take the square root!
I hope you are aware that you are replying to a 9 year old thread
