What is raduis ratio in CST ( Rotate Face command ) ?
An_RF_Newbie
Member level 4
Member level 4
Hello,
This is my setting for getting familiar with the radius ratio in CST in Rotate face command.
As you can see the end radius is not the double value of the start radius as I set this value to 2.
( the start radius from the rotate axis is about 1 column but the end radius is (2.5 or 3.) ).
Yes, the calculation appears to be disproportionate. At the halfway point we'd expect the lower half of the object to have radius 1.5. Instead it's greater, about 1.75 (marked in red).
But then CST is intended more for doing rf simulations rather than hyper-accurate mechanical drawing.
Thank you BradtheRad for your explanation. I've thought about the CST fault calculation, but as I see the shape carefully it follows a function for this behavior because the edge of the last section is not tangential to the axis.
