What is possible Cause ?
aamiralikhoja
Member level 5
Member level 5
I am Using Pc Parallel Port In ECP mode. I am using Watcom "C" Compiler.
O.S is Dos. I am acquiring Data At 8kiloByte/Sec rate . Data is Valid.
when I increase Data rate (Strobe) to 16 KiloBytes/Sec ,Data ACQUIRED
is not valid. What is posibble cause . Data has specified pattern .And
i am storing data in buffer after collecting enough data i stores data
to hard disk.Data is corupted.
The Device responsible for transmitting the Data and the one receving should be Synchronised
Regards
dEVEN
