what is port 80h in PC?
Pinczakko
Full Member level 2
Full Member level 2
Taka Bonerate National Park, Indonesia
port 80h
I wonder what this port is for (port 80h) in PC architecture ? is it a debug port ? I mean used for debugging purposes using a POST (power On Self Test) diagnostic card ?
port 80h card
The port 80 seems not to be a physical port in a PC, but to be a TCP/UDP port used by the HTTP protocol.
i/o port 80h
Port 80h is the hardware debug I/O port.
Power On Self Test (POST) sends results for each test in coded form to port 80h.
hmm... really interesting, can you please explain more on this. And is this port is the one which is used by a "special card" called the POST card as I mentioned above?
