What is Polygon and what is path in IC layout?
sathi.ec
Member level 1
Member level 1
Bangalore
In an IC Layout, what is Polygon and what is path?
What are the advantages and disadvantages of each?
Thanks
Sathi
IC Layout
Polygon is used to draw complex shape of metal or poly.
Path usually to draw bus or interconnection straight.
Re: IC Layout
Paths are used to connect the general purpose interconnects , 90 degree bends...
Where as the polygons also serves the same purpose as that of the paths but these are more useful in drawing the 45 degree bends at the chip corners.
45 deg pathe are not acceptable ,u will get the offgrid errors.....by the tools like VLE,VXL..(Cadence)
vijay
Re: IC Layout
One main advantage of polygon over path is it aligns perfectly with grid for any angle.
Regards
Re: IC Layout
for path the width is set by default to the min width of that layer . it is very easy to draw for 90 degree . but for other angles polygons are used. with paths other than 90 degrees we get 'offgrid " errors
Re: IC Layout
we got offgrid errors while doing tapeouts and rectified them with polygons.
Re: IC Layout
Paths with 45 deg bends will definitely give the offgrid errors..
where asthe polygons with 45 deg wont give any offgrid errors...
vijay
