[SOLVED] What is octal buffer/Line driver 74HCT244? What does it do? and Explain its operation
Eshal
Advanced Member level 1
Nowhere :)
Hello experts!
What is 74HCT244 (Octal buffer/line driver)?
What does it do?
How does it work?
How does it produce its output?
Thank you
What is not clear?
Did you read the datasheet?
Octal = eight times
buffer = (current) amplifier
line driver = it has enough power to drive long wires/traces
HCT = High speed Cmos with Ttl level input; VCC = 5V, ViL = 0.8V, ViH=2V (about)
datasheet gives the most reliable and precise information.
Good luck
Reactions: Eshal
    Eshal
This is what I already know.
By the way, is this a current amplifier? How ?
Experts,
How does 74HCT244 can be a current amplifier? Please explain
It can deliver more more current at it's output than it consumes at it's input.
This power is supplied by the Vcc and Gnd pins.
Bye
Reactions: Eshal
    Eshal
