There is no negative frequency in reality... I guess that you mean on negative frequencu that you get from Furier transformations... Well these frequencies are from nature of Furier, because it is symetrical around y axis...
Think about phasors. In trigonometric Fourier series (an and bn) you don't need negative frequencies because the result is given by a sum of sines and cosines.
In exponential Fourier series(cn) the need for negative frequencies yields from the fact that for describing a real function with complex exponentials, it necessary two phasors, one turning clockwise and the other anti clockwise, thus the result is the proyection the phasors on the axis.
Tip: the phasors have same angular rate, same magnitude and opposite phase, that's the trick
as u r talkin abt the negetive freq in Fourier transform...as it is said it is a mathematical outcome....why it comes is , when u look at the fourier transform of the signal...it will be represented in the exponentials. just imagine...wat if u change the sign of the exponentials, ie., amkin the freq negative? all u r goin to get is the repleca of the positive value of the same freq....just do this u will understand it better...
hope it helps u....
