what is MIMO in smart antennas
salma ali bakr
Advanced Member level 3
does anyone have any documentations on MIMO in smart antennas
thanks
Salma
MIMO (multi input multi output) it is transmission technique that uses multi path fading to increase channel capacity by using more than one antenna, each antenna send different data at same time, in the RX the antennas (number of antennas at the RX must be equal to or greater than the number of antennas at the TX) combine the received signals and data are recovered
Also check this **broken link removed**
Please if I helped you press helped me button
