What is MIMO and its advantages ?
vkekk
Full Member level 3
Full Member level 3
Pls define with simple examples in the following...
What is MIMO? why we go for in communication.
benifits of MIMO?
what is difference between MIMO and multicarrier system?
What is Spatial multiplexing?
Re: MIMO
Give simple defination for understanding ....
Re: MIMO
it's a system that uses multiple antennas at the transmitter and the receiver side to create a radio link.
In MIMO systems, a transmitter sends multiple streams by multiple transmit antennas. The transmit streams go through a matrix channel which consists of multiple paths between multiple transmit antennas at the transmitter and multiple receive antennas at the receiver. Then, the receiver gets the received signal vectors by the multiple receive antennas and decodes the received signal vectors into the original information. Here is a MIMO system model:
where and are the receive and transmit vectors, respectively. In addition, and are the channel matrix and the noise vector, respectively.
Re: MIMO
We use this technology in telecommunications, because we want to obtain more and more data rate.
The benefits of MIMO is increasing data rate without spreading allocated bandwidth.
MIMO consists several transmitting and receiving antennas, hence there are several information flows. Transmission of all flows fulfils on the same frequency unlike multicarrier systems.
Spatial multiplexing is a method of segmentation one information flow with high daata rate on M flows with lower rate in transmitter, transmission, reception and incapsulation all this M flows again in one flow on receiver.
