What is meant by test jig in a PCB?
ict test jig
should be the ICT tester.
for you to test the functional of the PCB.
what is post & jig test for hardware
Its a automation process for testing the product during mass production.
Assume u have a product which need to go for mass production regularly,then the hardware team will construct a hardware platform in which they test some of the crucial points(functionality etc) before despatching for shipment,its sort of plug the unit into the platform and test the required functionality according to the some specifications.
Try to google with proper string,you shall get tons and tons of document from ,hope this reply atleast defines your requirement for now.
Regards
Ramesh
