what is meant by glueless architecture ?
emb_sys
egypt
also is there any good free dictionary or site that help me in embedded system acronyms
thanks
Hi
Glue-less means that no other silicon is necessary to connect the processors together. For example, The Nehalem EX with four full QPI can support glue-less 8-way system architecture. Each processor connects directly to all seven other processors with a half-wide QPI link, and uses the remaining half wide QPI to connect to the IOH.
Source:http://www.qdpma.com/SystemArchitecture_QPI.html
I dont know any embedded dictionary port so wide to cover everything. Sorry.
hakeen said:
Hi
thanks for reply
the reason for my qestion is that Rabbit semi conductor says
that they have an advantage of • The glueless architecture makes it is easy to design the hardware system
So is they mean that their processor can be connected to any processor directly without any chips in between ????
is that an advantage ??? - i think even multible of 8051 could be connected together then is 8051 considered to be glueless architecture too ??
emb_sys said:
...The glueless architecture makes it is easy to design the hardware system
So is they mean that their processor can be connected to any processor directly without any chips in between ????...
Per definition -it must be so.
Otherwise, its not said if it will work with absolutly full capacity_I think, these is the knowed "detail with a devil".
K.
