T
treez
What is meant by "coating" when PCB track spacing is concerned?
Hi
The track spacing calculator on this page….
https://www.smps.us/pcbtracespacing.html
…where it says “coating”, does that mean special conformal coating, or does it just refer to standard solder resist?
Also, on my desk I have a PCB. This PCB is sold the world over in the 100’s of thousands (EU, UK, Aus NZ etc etc) . It is an offline 220-240VAC Flyback with a drain voltage which goes up to 600V. It is for a general consumer product. The flyback FET is a TO220 with straight legs into the PCB…..the bare solder joints of drain and source are no more than 0.9mm apart…….the IPC2221B standard clearly states that this requires 3.5mm.
Do you know what is happening here?
Hi
