What is main difference between CDR and PLL?
surianova
Advanced Member level 1
ASIA
what is main different between CDR and PLL?
pll+cdr
Some digital data streams, especially high-speed serial data streams, (such as the raw stream of data from the magnetic head of a disk drive) are sent without an accompanying clock. The receiver generates a clock from an approximate frequency reference, and then phase-aligns to the transitions in the data stream with a phase-locked loop (PLL). This process is commonly known as clock and data recovery (CDR).
Quoted from:
"Clock recovery"
https://en.wikipedia.org/wiki/Clock_recovery
Regards,
IanP
CRD and PLL
the CDR is extracting the clock from random input data while the pll works on a certain frerence clock.
Re: CRD and PLL
then how to congfigure PLL to function as CDR?
CRD and PLL
u cannot , a special PD must be used as it alligins the phase and not like PFD which lock to the frequency
PD used for CDR are as alexander and hogg , refer to razavi's optical communication book for more details
Re: CRD and PLL
between CDR and pll , the different thing is PD scheme , generally
the pfd using in pll always cant use in CDR for pll
because of the data patten , hogge and alexader detect the rising and falling
this meaning is very important and differentation between pll and CDR
if u want to , find the opital book written by RAZAVI
Re: CDR and PLL
Can u explain to me how clock can be extracted random data bit stream?
Is it need sample and hold circuit? Or is it depend on the filter ?
CDR and PLL
hello,
for CDR there r some diffrent architectures of PD that can allign the phase of the clock to the ideal sampling point which is the half period point , each of the phase detector have its own theory of operatio there r many types like linear and Binary (bang-bang), u should refer to ch.2 and ch.9 in Razavi's optical communicaion it has good explaination of the theory of PD .
sample and hold can be used to extract the clock.
i dont think the filter has to do with the type of PD , as each of the PD's will be followed by GM-cell or CP to convert Voltage to current and hence the simple series R and C filter is used.
regards,
a.safwat
    surianova
