HI DEAR,
In electronics, leakage is an undesired imperfection of some dielectric materials used in capacitors, also known as dielectric leakage. It is a result of the dielectric material not being a perfect insulator and therefore allowing a leakage current to flow, slowly discharging the capacitor.
In semiconductor devices, leakage is a quantum phenomenon where mobile charge carriers (electrons or holes) tunnel through an insulating region. Leakage increases exponentially as the thickness of the insulating region decreases. Tunneling leakage can also occur across semiconductor junctions between heavily doped P-type and N-type semicondutors. Other than tunneling via the gate insulator or junctions, carriers can also leak between source and drain terminals of a Metal Oxide Semiconductor (MOS) transistor. This is called sub-threshold leakage. The primary source of leakage occurs inside transistors, but electrons can also leak between interconnects. Leakage increases power consumption and if sufficiently large can cause complete circuit failure.
Leakage is currently one of the main factors limiting increased computer processor performance. Efforts to minimize leakage include the use of strained silicon, high-k dielectrics, and/or stronger dopant levels in the semiconductor. Leakage reduction to continue Moore's law will not only require new material solutions but also proper system design.
