I don't use Cadence so my answer is general rather than specific - a port is simply a connection, an ideal source is a perfect voltage supply or signal source. A port named VDD has no voltage one it unless you add one - it is simply a named connection. Similarly a port named Vin might be used to connect to an input source or network.
