what is difference between OTA and OP-amp?
yikwon
Newbie level 6
Newbie level 6
ota opamp
I think they are same architecture.
why different name?
difference between ota and op amp
from my understanding, it is called ota when it only drives capacitive load
ota op amp
In simple terms,
Op-Amp is Voltage Controlled Voltage Source
OTA is Voltage Controlled Current Source
difference between opamp and ota
why different name?
OTA is currrent OP
OP-amp is voltage OP
Reactions: ahahah
    ahahah
difference between op-amp and ota
add something:
OTA's output resistance is very large.
while OPAMP's is small.
difference between op amp and other amplifiers
OTA is a TRANSCONDUCTANCE amplifier which means that it's GAIN is given by Io/Vin=A (For a certain Voltage input you will have an output current Io which will be A times Vin). This means that the output current is independent of your load value (in theory).
an OPAMP is a Voltage to Voltage amplifier. Its GAIN is given by Vo/Vin=A, which means that the output voltage it's independent of the load attached to the circuit.
hope this helps,
diemilio
what is ota opamp
why different name?
OTA is the current mode
OP-amp is the voltage mode
otas and opamp
FOR SIMPLISITY
OP-amp = OTA + Buffer
opamp ota
Added after 1 minutes:
Op-Amp is Voltage Controlled decive
where as OTA is Current controller device
difference between op amp and ota
capability of drving is different i think
ota versus op
OTA is opamp without buffer.
Opamp can drive high capacitive loads and resitive loads whereas OTA can drive only small capacitive loads
