What is center tapping in VCOs and how can I simulate it?
Sadegh.j
Advanced Member level 3
Center tapping
Hi
What is center tapping in VCOs and how can I simulate it in ADS/ Hspice?
Thanks
Center tapping
Are you referring to a VCO with a center-tapped coil? That's the only meaning for "center-tapped" that I can think of...
Re: Center tapping
Hi
This is exactly what I am referring to, could you please explain it.
Center tapping
Well, at the heart of any oscillator, you need a gain element and a feedback network. The feedback network is typically either a capacitive divider or an inductive divider - which is essentially a tapped coil. A tap is just a third connection somewhere in the middle of the coil. If you look at standard oscillator configurations such as Colpitts, Hartley, etc... you will see either a capacitive divider or an inductive divider. Another good reference on this material is a text written by Clarke & Hess, but it is out of print, I think. You might be able to find a copy at the library.
To simulate a center-tapped coil, just string a couple of ordinary inductors together. If the coil has some mutual inductance between the sections, you might need to use a different spice element....
Re: Center tapping
great, how does it increase the quality factor of the varactor?
Center tapping
You'd have to provide some reference to a paper or show a topology... Varactors typically have low Q as one of the tradeoffs for getting a wide tuning range, so I'm assuming the idea is to improve the tank Q by some kind of transformer-like network using the center-tapped inductor? I'd be interested to hear more - can you post a reference?
Re: Center tapping
Hi
There it is, it is also in:
A. Maxim, "A Multi-Rate 9.953–12.5-GHz 0.2-μm SiGe BiCMOS LC Oscillator Using a
Resistor-Tuned Varactor and a Supply Pushing Cancellation Circuit", IEEE J. Solid-
State Circuits, vol.41, pp. 918-934, April 2006. I could not find the paper on my PC.
also in
Thanks man
Center tapping
OK - So as far as I can tell, the center tapping is done here to allow them to split up the tuning capacitance into an MSB part and an LSB part. If we have a 2:1 stepdown transformer (this is equivalent to their center-tapped inductor), then impedances on the secondary side must be 4 times larger (2*2) to have the same effect as if they were on the primary side. So if you want to have some tuning capacitance on the secondary side (i.e. connected to the center turn), its effect on the tank resonance gets divided by 4 -- this allows them to implement a "fine" adjust, which combined with the MSB tuning capacitance across the entire inductor, gives them a good tuning range.
As far as the Q goes, I really don't think the center tapping does anything. The effect of resistance in the LSB capacitance is magnified by 4 times when you move it to the primary side, so unless you can reduce the parasitic resistance by more than a factor of 4 for a 4x increase in capacitance, it's not likely to yield any benefit.
Where does the high inductor Q come from then? I believe it is described on page 3 of the paper - They maximized inductance for a given area to reduce substrate losses, used SOI, and etched all the way down to the insulator. That means there is very little loss from the substrate -- no eddy currents, etc...
As far as the varactor Q goes, they're not using typical varactors -- they use constant caps with voltage controlled resistors -- see page 2 and reference 8.
Hope this helps
    Sadegh.j
Re: Center tapping
thanks a lot
