What is cds.lib default path used by IC5?
dd2001
Full Member level 4
Full Member level 4
cds.lib path problem?
When I check cds.lib path, and found many cds.lib under IC5 root directories, however, I guess there is only one good for IC5 to search,
Who can tell me the one I need to edit?
You don't need to edit it.
When you created a new library or stream-in a database, the new library will be append to the cds.lib by auto.
IC5 will search the working directory first, if there is no cds.lib, your
home directory will be searched, if there is still no cds.lib, the one under
IC5 root will be used.
in the file manager, simply edit the lib. by dummy lib., than save. you than will find the cds.lib under your working directory, else, creat a new lib.
otherwise, if you are using it for the first time, only cds.lib defined in the start-up file will be referred.
