cupoftea
Advanced Member level 6
We want to make a domestic household plant watering system for peoples' second homes which are usually empty. (also for when people go on holiday).
So , the plants are in racks, we wish to pump water from the household mains water supply into a low level sump with level detectors in it. Ie, a solenoid valve will open and allow mains water into the low level sump. Water will get pumped from the low level sump to the high level “tank”. From the high “tanks”, water will flow down to the plants by gravity through tubes. Moisture sensors will detect when more water is needed for the plants.
So, power will ultimately come from the mains. What is the best isolated DC system voltage to use? Ie, which voltage is best for powering the pump and solenoid? We want it cheap as possible, but we also want it all to last as long as possible. I mean, 12V?, 24V? 48V? At what voltage are these pumps and solenoids cheaper?
(There is a rainwater “channel thing”, which also directs rainwater into the low level sump, so hopefully we wont need to switch the mains water on too much)
