ss_engg
Member level 5
What is inductor basically means if we untwist that coil and make it straight wire still it will be called inductor.. ??
kindly response me ...
Thankyou
Thankyou
Let me make you clear what i actually think an inductor is! Inductor is basically used to store magnetic energy when current flows through it. Actually, when current flows through a straight conductor, the conductor still stores the magnetic energy, however, it is very negligible as compared to a coil. It is because the energy stored is directly proportional to the area of the conductor which is obviously larger in case of a coil. (For detail refer https://farside.ph.utexas.edu/teaching/302l/lectures/node103.html This energy is then used up by the load for a short instant as soon as the main source is switched off.. The inductor's associated magnetic field then collapses...What is inductor basically means if we untwist that coil and make it straight wire still it will be called inductor.. ??
Thankyou
what is the main logic behind twisting the coil ?
