what is armel and armhf in os image
ep.hobbyiest
Full Member level 4
Full Member level 4
what is armel and arm armhf in os image type. while downloading kali linux image there was option as like this.
what is that image where it is use for ?
is it for arm or something different?
here is image of that page
hi;
armel arm little endian
armhf arm hard floating
As i know (not sure), hard floating must be supported by arm cpu version which you use. A soft floating executable can run on hf OS. hf helps to speed up some processes, since it uses hardware support of cpu to perform floating point operations.
Endiannes is related to OS, little endian executable can run on big endian and vice versa...
Have a look here
