What is a vi editor and how to use it in Windows?
lcs81
Member level 3
Member level 3
What is vi editor? is there any vi editor can use in wondows?
thanks.........
Re: vi editor
vi editor is a basic text editor for UNIX Open OS. In the past, maybe now too, GNU C programs were edited or written in vi editor. It's doesn't have fantastic functions or tools as current ones most people used in Borland C++ builder, Visual C++ or even UltraEdit32 etc found in Windows.
Re: vi editor
Now a days vi editor is not used that much beacuse it do not have graphical user interface. gvim editor is getting popular on linux with it's graphical user interface. VI editor is having a powerfull set of commands and multi level cut/copy buffers.
there is windos ports available for VI editor who is used with unix and can be downloaded from
https://www.winvi.de/en/
the gvim for windows can be downloaded from
https://www.vim.org
direct link to gvim6.4
ftp://ftp.vim.org/pub/vim/pc/gvim63.zip
Cheers
Re: vi editor
How can I configure my Vim in windows ? .. I have downloaded Vim 6.3 .. and I want it to have some default configuration when I use it to open files .. something like a default font .. default font size .. things like that .. cuz I don't like the default font it opens with ..
I don't to change the font each time I open the editor ..
Re: vi editor
Set your VIM environment variable to the location of your vim configuration file (.vimrc for example).
In your autoexec.bat or whatever, do something like:
VIM=C:\.vimrc
Then in that .vimrc file you have your specific configuration information.
Hope this helps and good luck.
Re: vi editor
VIM=C:\.vimrc
u replied one part of the question .. the second part is what to write in this file so as to change the font ? .. just the same command I mentioned ? .. and anywhere in the .vimrc file ?
Re: vi editor
To change the font in the .vimrc
set guifont=\Courier\ New\ 10
For example.
vi editor
Did that help?
Re: vi editor
The vi editor is one of the first text editors. It is very powerful. Once you start using it and get used to its plethora of features, you will hesitate to use any other editor. My sincere advice to you is to use it and learn it, if you want to become a linux/unix power user.
Added after 11 minutes:
VIM=C:\.vimrc
To simplify matters, you can simply edit the _vimrc file in your vim install folder
