What is a driver circuit referring to MOSFETs?
Sputnik
Full Member level 3
Full Member level 3
South Africa
New to MOSFET!
I am new to MOSFETs and have never used them. What is a "driver circuit" that I read about quite often when MOSFETs are involved and is it completely necessary? Or do MOSFETs work similarly to transistors?
Thanks
Sputnik :idea:
Re: New to MOSFET!
Well, the MOSFET works much like a transistor, but there are differences.Check out this document. It's old, but you can get an idea: www.onsemi.com/pub/Collateral/AN913-D.PDF
MOSFET drivers are used to speed up the switching action. Although they do not require a static drive current, MOSFET's have relatively large capacitances, which need to be charged/ discharged when turning on/ off the MOSFET. Charging/ discharging these capacitances requires a lot of dynamic current. This current is provided by the MOSFET driver.
A MOSFET driver is in fact an IC with a push-pull output stage, capable of sourcing and sinking the large current the MOSFET requires for fast switching.
Re: New to MOSFET!
More info you can find here:
another good source:
Re: New to MOSFET!
Hi
you can find many topics about mosfets on the internet, you can find many drivers about them on the internet. i have used ICL7667 and it was good for me. you can try it.
masoud
Re: New to MOSFET!
It's depend on how big input capacitance for your MOSFET and how fast your circuitry is. If just a small MOSFET and switching frequency <100KHz, a simple TTL gate should be OK.
Re: New to MOSFET!
Mosfet drivers are normally employed in switching regulator to improve the efficiency, this is because of the reduction in switching losses arising as a result of shoot thru if your charging/discharging edge is slow.
therefore, u need to evaluate your system before deciding to invest in a mosfet driver or not.
New to MOSFET!
I think a driver means amplified the signal's drive ability.
