jp619
Junior Member level 1
In a ring oscillator, I believe the oscillation takes place due to the delay provided by not gate. pls can anyone tell me the relationship between inverter being in even n odd no. have to do with oscillation... :-?
If you chain an even number of inverters together, there will be no oscillation. The inverters will stabilize and hold their value. Try drawing the circuit diagram and trace the signal as it passes down through the inverters and wires and you will understand why. If not, you are lacking basic understanding and should go back and study the basics.
