What happens when segmentation faults occur?
sacrpio
Member level 3
Member level 3
Hello All,
While compiling C program sometimes segmentation faults come. What happens internally with operating system if such type of fault comes. What is core dumped.
Thanks in advance.
Re: Segmentation Faults
visit to:
h**p://www-ee.eng.hawaii.edu/Courses/EE150/Book/chap7/subsection2.1.3.2.html
h**p://web.mit.edu/answers/c/unix_bus_or_seg.html
enjoy
for the lazy ppl who don't want to visit the second link and read the info there:
Segmentation fault means that the program uses area in the memory that isn't allocated to it. Most of the time it happens when using arrays and don't do bounds cheching (meaning you try to read the 5th element in an array of 4 ;-) )
Core Dumped (they have seen way too much star trek) means that the when the program chrashes, all memory used by the program (+ all other usefull info like from CPU) is written to a file that can be examined later (gdb can be used for that matter)
Antharax
Segmentation Faults
Little addition - this error is mainly relevant to processors where memory management unit is used (MMU) where access to different memory positions are guided under hardware control . In non mmu processors you can just get crashed program . For simplicity and speed reason run time libraries do not include input range check when their functions are called . But there are also libraries where software argument checking is enabled - to make safe buffer overflow protected software(e.g. communication libraries ).
