What happen's if priority change
Daljeet12
Member level 4
Member level 4
I am trying to understand what happens if we change priority in code in given link https://www.digikey.com/en/maker/pr...t-2-freertos/b3f84c9c9455439ca2dcb8ccfce9dec5
C:
//  task 1: blink an LED at one rate, Hight priority
void toggleLED_1(void *parameter) {
  while(1) {
    digitalWrite(led_pin, HIGH);
    vTaskDelay(rate_1 / portTICK_PERIOD_MS);  // blocking for 500ms
    digitalWrite(led_pin, LOW);
// task 2: blink an LED at another rate, low priority
void toggleLED_2(void *parameter) {
  while(1) {
    vTaskDelay(rate_2 / portTICK_PERIOD_MS); //blocking for  323ms
Here I start to think
Task 1 run because of high priority
Task 1 block for 500ms
Task 2 run because Task 1 is blocked
Task 2 block for 323 ms
Now stuck there I am looking help to figureout how both task execute over time
VTaskDelay stops the task that calls it but it does NOT block other tasks - in fact it can trigger the task scheduler to see if there is another task that can run.
The task priority only really kicks in when you have two tasks that ca run and then it picks the higher priority one.
Susan
