wangliangk
Newbie level 5
There is a varcap in a RF IO PAD and we connect both the N-well and P-sub to the ground, what will happen? And how to solve this problem?
Thanks!
Thanks!
vijay.kumarreddy said:U will definetly get the latchup issue. during DRC verification u will get theMulti stap error( ie Wells at different potentials).The N-Well and the P-substrate junction forms a diode which should be always be reverse biased to avoid the minority carrier injuction to the substrate which causes the triggering of thr parasitic BJT wht we used to call this phenemonon as the Lath up.So to avoid this we have to connect the N-Well to the VDD.Same for the case of the P-sub also.
vijay
