What functions are declared in "string" module ?
trurl
Junior Member level 2
Hi All,
I'm a beginner with c++ (MS VS 2005). I need to use module "string". I tried to find in MSDN what functions are declared in this module, but did not succeed. Could anybody help looking for this info in MSDN? The problem is that I get a lot of search results, but none of them is about the module itself. Thanks in advance.
Regards.
MS VS C++ 2005 help
'string' is part of the STL, the standard template library of C++.
Not anything done by microsoft.
If you just include string:
#include <string>
then declare a variable.
std::string myString;
then type the variable and a full stop,
myString.
visual studio will then list all the functions and operators that can be used with string.
Google for the STL, you should find info about the string templates there.
    trurl
