What error is this how to remove?
RETGT
Banned
Full Member level 3
Hello,
How to remove error and install lampserver.png this package from terminal window?
please tell more about error dpkg?
Try typing "dpkg --help" or "man dpkg" for help.
Almost all Linux programs have a help facility built into them '--help' and also have an entry in the help manuals 'man ....'.
Brian.
Reactions: RETGT
    RETGT
Please close all open programs and then restart your computer.
Once you have booted and logged in, open a terminal and then install lamp-server via apt. You must be connected to internet before you issue this command. Do not start another update or similar process at the same time.
If you still get the same error, go to /var/apt/ and delete the lock file. Then rerun the apt install command once more.
It is not difficult but some prior knowledge is useful.
hello,
What is command for lamp server?
xamp.pnghello i follow this and show me this
The same command you have used: sudo apt-get install lamp-server
you can also try removing the lock file at /var/lib/dpkg/lock; use command sudo rm /var/lib/dpkg/lock to delete
The MSCORE fonts are being installed; it is not an error; use the tab and select ok and press return.
it say unable to locate lamp server.
