anan1975
Member level 3
- Joined
- Aug 10, 2009
- Messages
- 57
- Helped
- 1
- Reputation
- 2
- Reaction score
- 1
- Trophy points
- 1,288
- Location
- Noida india
- Activity points
- 1,662
hi
i design a smps supply in forward push pull topology with following specification
Np-primary turns 17-0-17
Ns -secondary turns 14-0-14
ip volt 75-85
op volt 5-48 volt adjustable
op amp 2.5 amp
swg 24 for eitherr side
core 424210
Lp pri inductance 300 uh(17-0 in 17-0-17 side)
frequency-45 khz
oscillating device sg3524,mosfet irf840.
i got the result as i required
and if i change the gap of core and got Lp-100uh, And if i reduce the gap Lp 400uh
what will be change?
Regards
anand
ip volt 75-85
op amp 2.5 amp
core 424210
frequency-45 khz
Regards
anand
