What does this circuit do in the Push pull convertor
azadfalah
Full Member level 2
Full Member level 2
Hello friends,
I'm checking the circuit of a pull-pull converter and I encountered the following circuit
What does the following circuit do?
Frequency = 50hz
thank you
I assume this is not the complete circuit ... not enough to answer your questions.
Also some informations are missing like: waveform, voltage...
I recommend to use some simulation software like LTspice.
Klaus
voltage = 24 V
Waveform = Square
Pulse width = 15% - 25%
I think if its a snubber you need something to discharge those capacitors.
The capacitors are discharged by the RCD circuit, a bit unusual however.
