What does the term "gain" mean in reference to antenna?
evl_inside
Member level 2
Member level 2
Mars
Hello,
can any one explain me what is the Term "Gain" means in reference to Antenna?
and how does it affect the range between the modules.
Thanks in advance !!
Re: Gain in Antenna
Your question was already answered here:
See Balanis's book here (but there are some others here if you use edaboard's Search):
Regarding your second question, if you use antennas with certain gains for both the transmission and the reception, it means for your system that for instance you can use lower transmitter power to cover a given distance than you would have to use when you had antennas with no or lower gains.
unkarc
    evl_inside
