What does report_timing do ?
vivek_p
Full Member level 1
Is the path which we get when "report_timing" command is entered in Design Compiler , the critical path of the design?
When I synthesised the design , I got data required and arrival time as 16 ns
I synthesised the design again after an addition of a latch. Then I got the "latch path" when I entered "report_timing". The data required and arrival time is 4
ns
When I checked the old path using report_timing -from ... -to I got timing as 16
Why is it so? Doesn't "report_timing" give critical path or else is it an exception when latches are synthesised?
report_timing
report_timing shows the most critical path (it may show the most critical path for each clock group)
critical path is defined as worst negative slack, which is the difference between data required and arrival time. When you time with latchs, time borrowing may happen and your required and arrival times will be the same and slack will be 0. If this is the case, this path isn't neccessarily your most critical path. You can check more paths like this:
report_timing -path end -max_paths 100
    vivek_p
