What does pseudo-differential mean?
danesh
Full Member level 3
Full Member level 3
what is Pseudo -Differential?
Re: Pseudo -Differential
Psuedo differential is an architecture where, the common mode point is ground. You actually get two single ended branches together and then supply opposite signals at their inputs and then take the relative output between them.
Pseudo differential architecture is used in Low Voltage Design. It helps us to avoid, the loss of swing due to the Common mode constraints.
check out hstl and sstl standards
