What does flipchip design mean?
aravind
Advanced Member level 1
india
what is flipchip design
hi friend
what is the meaning of flipchip design
It's one type of BGA package. See Xilinx "Device Package User Guide". Search for section titled "Flip-Chip BGA Packages":
There are two main differences between wire-bond and flip chip.
- In wirebond, the I/O pads are placed around the die. In flip-chip, they are placed all over the die.
- In wirebond, the die has the top metal layer facing up, in flip chip, the die is flipped upside down (hence the name), with the top metal layer facing down
Re: what is flipchip design
flip chip means, the ios will be placed on bottom of the die also, not only in sides.
Not necessary. Both placement types exist on each technology.
aravind, you can find more details from these sites:
www.amkor.com/enablingtechnologies/FlipChip/index.cfm
Advantage of flipchip (from these website)
•Reduced signal inductance
•Reduced power/ground inductance
•Higher signal density
•Die shrink
•Reduced package footprint
    aravind
