henninggs
Member level 2
Hi.
I'm new to all this and learning every day.
This might be a very basic question and I do think I have understand it the correct way, just need to be sure.
I have a quad bus buffer, the 74HC125. In the data sheet it says:
This means that if there is no signal going to the !OE pin the device is enabled, right ?
But does "active low" also mean that the device is enabled EVEN if there is no current on the Vcc pin ?
Is the 74HC125 "enabled" when I hold it in my hand not connected to anything - or will the state be "undefined" if no power is supplied?
The “125” is identical to the “126” but has active LOW enable input
