PAL: registered trademark of AMD/MMI
GAL: registered trademark of Lattice
In the beginning there was MMI (later accquired by AMD) which manufactured the original PAL (programmable array logic). This was the opposite part to the TTL PROMs. The original PAL was not erasable, it was just OTP (one time programmable).
Later Lattice came and produced electrically erasable PALs, they called it GAL (general array logic). They also introduced a significant enhancement: the univeral output cell which could be a straight output, a registered output, tri-state etc.
Later on AMD/MMI enhanced their OTP-PALs to the more general structure of the GALs, they made their PALs erasable, too, and called them PALCE.
So a GAL16V8 is similar to a PALCE16V8. Other well known types are 20V8 and 22V10.
Programming algorithms differ from type to type and from manufacturer to manufacturer.
The cheapest method of onboard GAL programming can be done with
Lattice's ispGAL family. This is one member family with PLCC 22 housing and with 22V10 core. It can be programmed using programming cable (datasheet available on the Lattice website, together with the programming software).
Happy to be of some use to this good forum,
djolestojic
Happy to be of some use to this forum,
djolestojic
djolestojic
