Here are some type of sheilding done within mixed signal ICs,
1. Sheilding for clock path (High frequency)
2. Sheilding for data path (High frequency)
3. Sheilding for reference voltages.
4. Sheilding for Bias lines.
Following may help you,
1. If Signal in Met1,
bottom plate --> Poly
top plate --> Met2
Either side --> Contact and Via
Connect all plates to either POWER /GROUND depending on situation.
2. If signal in METx
bottom plate --> Met (x-1)
top plate --> Met(x+1)
Either side --> Via(x-1) and Viax
3. For differential signal routing run a GND signal between them.
Thankyou dinesh, Can u plz tell me if a signal is to be sheilded, can v provide one side with VDD metal and other side with GND metal sheilding...? if yes why ?
