What are the rules or standards for high current tracks?
HINDI
Member level 3
Member level 3
MISR "EGYPT"
high current tracks
I m designing h bridge for a dc motor that will handel more than 40 AMP
when loaded . I've understued from the protel help that there is some thing called "power plane"that is a thick track capper voided in the PCB with a depth.
Is there any rules or standards for this high current tracks .
HINDI@GAWAB.COM
Re: high current tracks
I wouldn't advice transmition of currents of this level through PCBs.
Current paths of this magnitude should go through copper wires!
With high oz and parallel trace anf distributed via, but still 40A is too high.
high current tracks
What about those power traces on motherboard? If I'm not mistaken, CPU current can go very high (100A ?)
It is certainly possible to pass 40A in a normal PCB track.
But it will depend on what is acceptable for your application.
For a DC current of 40A you will have the approximate temperature rise for the following track parameters:
W=40mm, t=35um -> T=13 degrees
W=30mm, t=35um -> T=20 degrees
W=30mm, t=70um -> T=7 degrees
W=20mm, t=70um -> T=14 degrees
W=track width
t=track thickness
T=temperature rise for an external track
Provided that your track is not an internal track those values should hold.
Hope it helps.
S.
    HINDI
Hi, 40A is very high current !
If you have an area with 40A, and you have only 1 or 2 internal layers,
connect the 2 layers area with moore metalized holes, best without thermals.
Other important consideration is the 'correct' width of area in planes, for not
rise high temp. °C, in pcb.
If the area in a mulitlayer board are little, you need moore layers and connect all planes with metalized holes. Moore layers because the thickness if internal layers are 0.5 or 1oz.
Another choice, use a double side pcb, but with HIGH Thickness copper 2 or 3oz, with high copper thicknees you need a lower copper areas.
Hope this help, let me know. Best, Skywalker.
high current tracks
You can now get alliminium plate that you can etch your circuit onto, it's available from Farnell. Or if you go to a manufacturer of pcb's, they can even do copper based pcb's. This is what you need for your output power module. Screwed down onto your heatsink. With 2 ounce, or 4 ounce copper layer, 40 Amps is no problem. You need a track width of at least 100mil and not to long, but flood as much copper around your track that can fit.
My baby does 45Amps, no problem.
Iv'e seen a board for a fork lift truck motor, on 3mm copper plate, draws 100Amps! Uses 12 Dsquared mosfets in parallel!!!!
    HINDI
Re: CALCULATION & STANDARDS
THANKS FOR ALL , BUT I WANT MR SINATRA TO GUIDE ME TO THE RESOURCES
" EQUATION + GRAPHS +STANDARDS " THAT HIS CALCULATION BASED ON
MR SINATRA , DO YOU HAVE ANY RESOURCE OR WEB ADDRESSES FOR THE
PCB & WIREING STANDARDS MIL-STD-275 & IPC-D-275
THANKS
IPC Standards are available on fileman
    HINDI
Re:what is the file man
could you please guide me to the exact address , because i do not know what is the fileman you talk about
thanks
high current tracks
The LINK to the site is available at the Left-Top at EDABoard main page.
Or, fyc, here is the link:
high current tracks
HINDI, get MIL standards such as MIL-STD-275E (cancelled) from here:
    HINDI
HI , THANKS FOR ALL, BUT I'VE RECIEVED AN EMAIL FROM IRF.COM AS AN ANSWER FOR MY Q IT WAS :
IPC-D-275 is a design standard for rigid printed boards and Rigid Printed board assemblies.Now, It is withdrawn and replaced by IPC 2222 & IPC 2221 . You can decide your pcb track according to these standards.
International Rectifier <tac@irf.com>
THANKS
Yes - and those calculators use IPC as their basis.
Git
There is an economic aspect to this. The cost of PC material to make these high current traces is much more than the cost of ordinary wire that could carry them.
the maximum current that PCB can handel is 100 A.
HINDI,
From a purely economocal standpoint that may be a good rule, but boards are designed for, and are in use, that carry 400 amps or more - very expensive but feasible, I've designed a few myself. In the past solid plane layers, (not traces), of 10 Oz. copper (.3 mm) thick have been used, but 5 Oz. and below are more common these days.
SiGiNT
    HINDI
See it!
you can solder a small busbar or a thick tinned wire over the track to increase its capacity. if the qty is large a busbar punced from a copper sheet can also be used
