HouJun
Newbie level 3
I designed a simple single-step strip-line directional coupler.
the sumulation has coupling degree of-40dB, directivity of 30dB from 350MHz-600MHz,
but the test results of directivity is almost 0. I do not know where the problems lie in.
feeling there is no theory problem, should be the wrong choice of substrate ? (I am using Rogers4350).
and my stripline coupler is connected with microstrip line. will the discontinuities of strip line to microstrip line cause these Deteriorations?
This is the first time I designed directional coupler. I wonder if there any recommendations?
