shahbaz.ele
Advanced Member level 1
- Joined
- Aug 12, 2008
- Messages
- 454
- Helped
- 72
- Reputation
- 146
- Reaction score
- 73
- Trophy points
- 1,308
- Location
- Islamabad, Pakistan
- Activity points
- 3,669
dear all
I have a system with circuit that converts RS232 signal into fiber optic signal and then at the receiver end again same circuit converts fiber optics signal to RS 232 signal and then to computer.
Problem I am facing is that I have to operate it at 12VDC (as power supply),
in converter module I used 7805 regulator (complete circuit of converter designed in my LAB),
both things a fixed; supply voltage is 12VDC and module needs 5VDC.
The regulator heat up extremely great temperature.
what would be possible solution for it.
in converter module I used serial, counter and crystal ICs that needs 5VDC.
