What are the meaings of the following Calibre warnings
aditya1579
Member level 2
Member level 2
What do the following warnings mean in Calibre ?
- WARNING: Cell <cell name> is referenced but not defined. Empty cell used
- WARNING: Cell <cell name> already exists, will overwrite
Thanks,
Aditya
don't know anything about calibre
taking a stab in the dark
you used a cell name that was not previously defined.
such as putting a variable in an equation when you did not specify anything about the variable earlier
this seems like you defined the same variable name (cell name) twice
both or either may be the result of a misspelled cell name
Thanks,
Aditya
Assuming you are using calibre for DRC, these errors happen when you generate broken GDS. Maybe the reason is a library is missing, maybe the reasons is two libraries have cells with the same name.
