What are the main manual modifications to add to .spf file ?
akrlot
Member level 3
Member level 3
tetramax spf
hi;
what are the main manual modifications to add to .spf(stil protocol file) which is generated by dft compiler in order to use it to test transition faults.
thx
spf tetramax
add some primitives and constraints about PI/PO !!
    akrlot
spf tetramax
You must provide initial sequences, if you have some initial action that make the chip into test mode.
    akrlot
spf tetramax
wkong_zhu comment correct, on top level, you need initilization sequence to enter test mode. ( like configuration JTAG register)
